Flux slipper clutch adjust ?
I have burned slipper pad because from factory it too loose and hpi recommand "Tighten set screw fully then loosen one half turn" after rebuildind I loosen 1/8 turn and all working good no more slipping clucth and wheelie all time and now did we think is better to loose slipper at minimun 1/4 turn for protect the drivetrain or 1/8 it ok ?
Thank ! |
sounds like you got it right where it needs to be..for my BL ERevo I had teh same setting till I wore it out even more then it was tightened all the way till I finaly finished it off..I got a rebuild kit on order..you may want to have some spare slipper clutchs cause it sounds as though you may need some too with that BL power
| All times are GMT -4. The time now is 07:34 AM. |
