Hyperion Duo II
Can someone explain to me how to cycle nimh batts. I have read the manual and no luck.
I have a Hyperion ac/dc charger as well but it discharges at 1amp and a cycle takes way too long. Thanks in advance. |
I dont beleive the Duo does cycling per se'. I've had mine for a little over a year, and dont have any idea how to do it with that charger.
Does it discharge when you do the Storage mode? I've never put a pack on with it at full capacity to see what it does with that.... |
Select your Nimh profile setting >press and hold Enter >will read 'Charge Start' >press Down twice >Cycle Start appears. I haven't tried it but that will get you on the right screen at least.
anyone know how to change the default storage mode of 60% for lipo.
I use the TCS percentage to do a storage charge. Does yours have something different for doing a storage charge?
I have the orig duo and I hold enter then press down and it says storage. It then either discharges or charges the lipo to 60%
| All times are GMT -4. The time now is 06:44 AM. |
