MMM no worky in flux
I went down today to try to drive the Flux on 4S. Its been sitting for two long lonely weeks down in the dark of my garage, and thought I should give it some love. I loaded in my 2 new PQ 2S packs, turned on the DX3, flipped the switch, heard the initial "on" song it plays, but not the remaining "beep" "beep" "beep". Flipped the trigger FWD - nothing, Reverse - nothing. Turned everything off, and tried it again - same results. I checked steering, and it was fine. The yellow and green lights are on, but flickering somewhat (seem to recall this is normal). I double checked the plug into the reciever, but its good.
Two weeks ago, I reprogrammed the unit, and adjusted all the parameters - but it operated correctly when I shut it down. Any suggestions? |
try reversing the throttle channel on your radio?
Sounds like the bec died... You can try recalibrating it, and check to make sure that you have not altered the throttle channel expo, epa or any other settings to do with the throttle channel. Zero everything just to make sure and recalibrate it...
Is your LVC still set to 3s Lipo packs?
I don't think it was anything that you changed that (directly) caused it to malfunction like that, where it wouldn't drive AT ALL. It was probably "only" a firmware glitch... :neutral:
Main thing is it's working now, get out there and bash!
It sounds like to me it wasn't seeing Neutral on the throttle.
It's much better to play with one adjustment at a time if you can. LOL |
No doubt....
The only setting I can think of that would do what was described is setting the neutral range too small. If the ESC sees too much F or R on arming, it won't function.
I wonder if reducing the deadband on the DX3 will have the same effect? |
Depends on the radio. If there is too much "drift" in the throttle potentiometer, setting a value too low would make it too sensitive.
I have had trouble getting it to arm when setting the deadband smaller on the esc (also using DX3). I just leave the default esc deadband setting and have had no problems since.
I will likely leave it alone. I didn't have much of a reason to adjust it - its just that the "dial" was there, and I had to turn it......
| All times are GMT -4. The time now is 05:57 AM. |
