water cooler for finned motor?
yes its for a boat
anyone got any ideas on how to build a water cooler system for a neu castle 2200kv motor I'm thinking of just making a coil around motor with aluminum tubing...would copper be better?...easier to bend be pretty nice if you could devise some way of making a slightly bigger can to fit around the fins and sealing the ends with o-rings and sealant like on the smooth can coolers where the water actually flows over the motor |
Coils wont work at all well with a finned motor, very little contact area.
if you could find a metal/ plastic sleave just slightly larger than the motor diameter, and seal it like you said (or with silicon/jbweld etc), it would be easy to install the nipple inlets and then run the tubing where it needs to go. |
Find copper small enough to fit in between the fins, and you could make a very effective one.
That occured to me too, but the tubing would need to be ~3mm OD at most by the looks of the motor, never seen anything that small very often. Copper would be best though yeah, better conductor or heat so far as I know compared to aluminium.
how big of a boat?
Find a lathe...
Or send to NEU pay some $ and ask for a smooth can...
Personally id go with the tube idea.
1. Id Lathe out a tube of copper or aluminum to fit snug on the fins 2. Lathe and weld some bungs for the water inlet 3. Grind the fins right over the bung about 1/4" so the water flows around the motor 4. Seal with some silicon or anything similar. |
Try this from www.fastelectrics.com edit: I posted without reading your last paragraph & I now assume you have a finned can? They do a larger one that may fit over fins although I doubt it would be effective even if it did |
why?...same principle |
| All times are GMT -4. The time now is 07:52 AM. |
