-   -   kyosho mini inferno ST (https://www.rc-monster.com/forum/showthread.php?t=1920)
auto2 12.30.2005 05:44 PM
hey guy, I just bought a half 8ST and it is begging me to put a brushless in it.
I read a few posts on half8.com and mamba motor is too small?
so mike! before I get my properity tax bill what you got in stock?
here is a post I read:
I would highly recomend staying away from the Mamba stuff.
Just dosn't work well in the H8.
The motors are to small and the 25 ESC is like an on off switch.
If all you'll ever do is run it up and down the street it works.
But if you use it on a track or stop and start alot or use reverse much it seems to over heat and then it starts cogging. The more it cogges the hotter it gets before long you want to toss the whole lot in a trash bin.
You can get lots of advice on how to fix it but the bottom line is don't go there.
I only bought the mamba setup for the H8, I tried every fix,I ended up selling it.
I would suggest the Tekin ESC it has a very smooth throttle curve.
The AON motor is also very good. The hacker 4900 works very nicely as well.
The Tekin, Hacker, and a 3 cell Lipo is a great combo.
If you search BL motors here you will find several more motors that work.
Its vital that they have very good tourque. I know Tekin is working on a bigger motor they are testing it first,in a half 8 so I hear, and I would bet if it has the same performance as there speed controls it will be a good choice as well.
I like the novack xxl rec. and just about any good servo can work.
I would wait untill you have the H8 in hand and see if some of the componets you have will work first.
Just stay away from SMALL BL motors they have real trouble with the H8.
http://www2.towerhobbies.com/cgi-bin...?&I=LXKYN7&P=7
Skelbow 12.30.2005 05:59 PM
I would assume the Mamba motors have the same problem in the Half 8s, as they do in the Mini Quake.
I've never heard of anything bad about the controllers, just that the motors are too small to drive the MQ or in this case, the Half 8.
the motors that come to mind to me are :
Aon 4900
Hyperion 5000 Long Can
Warp4 2 Turn
I just did an order from a different site for my Mini Quake.
Mamba 25 + Warp4 2 Turn + 3S Li-Pos. Seen videos of this setup pushing the MQ to 40+ MPH.
auto2 12.30.2005 06:07 PM
well I guess I can strip my emaxx and put that stuff in there!LOL everybody DUCK!
hey mike ; when you find this thread call me and we make some business.:-)
