Zippy flightmax 3s 2200mAh in DX2.0
up until this point have been running a maxamps 3s 5000mAH in this remote but because of its size i had to tape it to the bottom. Though this worked it was heavy and did not look to good. so i bought a 3s zippy 2200mAH that fits perfectly and did dome mods to the remote so i can charge and balance without taking the battery out (which would require me to open up the whole thing).
here ya go, let me know what you think! http://i582.photobucket.com/albums/s...1/DSC_0174.jpg http://i582.photobucket.com/albums/s...1/DSC_0175.jpg http://i582.photobucket.com/albums/s...1/DSC_0176.jpg http://i582.photobucket.com/albums/s...1/DSC_0177.jpg http://i582.photobucket.com/albums/s...1/DSC_0178.jpg I haven't charged the pack yet as im waiting for the balancing tap (back-orded), but the pack reads 11.6V |
I'm glad you found a good use for your old maxamps...
This is really cool! I just want to show you - http://www.hobbycity.com/hobbycity/s...ack_(Futaba/JR) It would probably last longer per charge not only because it is more mah but also because it's designed to discharge so slow. |
"It would probably last longer per charge not only because it is more mah but also because it's designed to discharge so slow"
mah is mah, does not matter what the discharge rate is. It is not designed to discharge slowly(you cannot design that), it is just incapable of discharging quickly... I do agree that he could pick up 300mah worth of capacity, but he will also have a one use battery, he can always take the pack out of the radio and use it in a mini if he wants... I like having lipos that will do a few tasks. I have a 18c 3s 2500 mah lipo in my m8, just cause it fit and I already had it... |
| All times are GMT -4. The time now is 05:57 PM. |
