gearing for medusa
Hello I have a kyosho kanai converted to electric with Mamba Max esc+ ubec + 4s zhippi 5000mha 20c and medusa 2000kv 60mm. What gearing can I use? I have pinions of 13t, 15t, 17t and 19t, my spur is 46t and mys diffs are 43/13
Regards |
I would start w/17 and check temps....that way you can go either way w/gearing
http://www.scriptasylum.com/rc_speed/_top_speed.html
As seen, a 17t pinion will yield you 37mph A 19t pinion will yield 41mph |
In my calculation it is different, on 17/46 :
Differential Ratio: 3.3076923076923075 Transmission Ratio: 1 Other Ratio: 1 Spur Tooth Count: 46 Pinion Tooth Count: 17 Total Voltage: 14.8 Motor KV: 2000 Tire Diameter (inches): 4.5 Tire Ballooning (inches): 0 Motor Current Draw: 0 Motor coil Ω: 0.006 Spur/Pinion Ratio: 2.71 : 1 Total Ratio: 8.95023 : 1 Tire Circumference (inches): 14.14 inches (359.08 mm) Total Motor Speed: 29600 RPM Vehicle Speed: 44.27 mph (71.12 km/h) Effective KV Value: 2000 on 19t: 49.48 mph, on 15t: 39.07 mph and on 13t: 33.86 mph Regards |
i use the 36 60 2000 motor in my buggy on 4s and it has the 43/13 diffs. i am racing it on a smaller indoor track and using a 14/44 setup. it has really good power and runs cool at 110 after a 5 minute run but the indoor temp is only around 55 to 60f.
running it outdoors on larger tracks i will try a 15 tooth if it dosent get too hot. honestly it has great racing acceleration and speed with the 14 tooth. i would think a 17 tooth will get you into trouble. also those gearing charts are misleading at times. when i had my novak 6.5 system in my car i clocked it at 37 with my radar gun. i havent clocked it with the medusa and 14 tooth but i can tell you it is faster i would say 40 or a shade faster. always gear your car so it runs at a pace you can handle but most importantly dosent get the system hot. |
| All times are GMT -4. The time now is 02:04 AM. |
