-   -   Which 3s pack? (https://www.rc-monster.com/forum/showthread.php?t=19332)
Jeremy1976 03.11.2009 08:57 AM
Which 3s pack?
I am in the market for a 3s pack for my Slash. I want the best I can get for my money. Here are my 3 options. Which one would you get and why?
1. http://www.rc-monster.com/proddetail...pq3s6000mah25c
2. Thunder Power TP5000-3SP30 Li-Poly Battery In Stock $164.99
11.1V 5000mAh (3 cells) Pro Power Series
Rating: 30C (150.0A) continuous, 60C (300.0A) burst
3. Poly RC PQ-5000XQ-3S Li-Poly Battery In Stock $132.29
11.1V 5000mAh (3 cells) 30C/60C
q8-maxx 03.11.2009 09:13 AM
go with PolyQuest lipo from RCM:
1- 6000mah (more run time)
2- 25C (150A) continuous, 40C (240A)
3- support RCM store :)
remember to check the size to make sure the lipo will fit your car before order :)
JThiessen 03.11.2009 09:15 AM
Originally Posted by q8-maxx (Post 268900)
go with RCM lipo:
Last time I checked, Mike didnt have his packs in a 3S config.
q8-maxx 03.11.2009 09:19 AM
oh sorry I mean PolyQuest pack
Sorry again
Jeremy1976 03.11.2009 01:00 PM
Any idea what packs in 3s will fit the Slash?
rootar 03.11.2009 01:14 PM
all of those listed will fit.
skellyo 03.11.2009 01:21 PM
You'll want something ~28mm thick or less if you want to easily use the stock battery bar. 25mm is the max without using spacers under the rear bar hold down and unscrewing the front a couple of turns.
From a fitment perspective, I like the size of the PolyRC 3S 25C 4350mAh. http://rclipos.com/PolyRC25C.htm
Jeremy1976 03.11.2009 03:42 PM
The thickness I am not worried about so much. I am going to be fabricating two velcro straps into my stock battery tray and get rid of the battery hold down.
E-Revonut 03.11.2009 03:59 PM
IIRC both of those are Enerland based cells, so essentially the same battery. Go with the cheaper selection. But also look into Neu batteries, also enerland but are generally on the lower end price wise.
Metallover 03.12.2009 08:27 AM
Found a Neu 5000mah 3s car pack for $111
http://www.flydma.com/product_info.p...roducts_id=267
