-   -   Tekno X2 Conversion (https://www.rc-monster.com/forum/showthread.php?t=19341)
Fast5sRevo88 03.11.2009 04:09 PM
Tekno X2 Conversion
Will the Tekno X2 conversion kit for CRT work on my X1?
skellyo 03.11.2009 04:14 PM
Any reason you don't consider Mike's motor mount and battery tray? It's a bit cheaper and the battery tray is a lot nicer IMO.
Fast5sRevo88 03.11.2009 04:43 PM
I have that stuff already and like it, i was just wanting to try something different.
teknorc 03.11.2009 06:05 PM
If you have the newer small center diff setup and the f/r truggy diffs, it will fit right up. It is not compatible with the larger spur gear from the X1 however.
skellyo 03.11.2009 08:33 PM
If the center diff itself is the same from X1 to X2, you can swap the 62T stocker on the X1 out for a 46T Kyosho spur.
