Will it work?
I see Mike has these mod1 pinion gears and offers a bore reducer to fit 1/8th and 4mm shafts. Will this pinion work with the stock spur gear on the Slash?? I have been searching high and low for 32 pitch pinions and the teeth selection is limited. I would like to run a 25t. Here is what I am speaking of. My other option is to try to get a hold of Mike and see if I can send back the 1/8th Medusa for a 5mm Medusa.
http://www.rc-monster.com/proddetail...=5mmmod1pinion |
The stock slash gear is 48p... You can put the jato spurs on for use with 32p, or the revo spurs for mod1. You can use the 5mm bore 32p or mod1 pinions with the bore reducer for use with and 1/8 shaft motor.
32p 1/8 bore selection only goes up to 22t. I would go with the revo 40t spur and mod 1 gears. |
Thanks |
and 18:62 32P is darn close to 25:86 |
You can get 32P traxxas spurs in the following sizes: 54, 56, 58, 62, 65, 68 and 72 You won't need a 25T pinion when the spur tooth count is dropped. Also, yes, the bore reducer Mike sells will adapt a 5mm bore pinion (32P or Mod1) to a 1/8th shaft motor. |
| All times are GMT -4. The time now is 11:04 AM. |
