-   -   mamba max question (https://www.rc-monster.com/forum/showthread.php?t=19402)
jlustig83 03.13.2009 08:04 PM
mamba max question
Should I use a ccbec with my mamba max esc when running 5s a123 m1 cells or should i not even worry about that?
E-Revonut 03.13.2009 10:02 PM
On a Mamba Max, yes an external bec is required when running higher voltages. If it's a Mamba Monster you don't need it.
eovnu87435ds 03.14.2009 12:10 AM
be sure that on the servo wire coming from the mamba max that you disconnect the middle red wire, so that you don't have the mamba and the ccbec powering your Rx and possibly damage it
jlustig83 03.14.2009 06:38 AM
what does rx stand for? radio something
magman 03.14.2009 07:55 AM
rx stands for the receiver.....just disconnect the red wire on the plug from the esc the plugs into the receiver. Don't cut the wire...either tape it out of the way or heat shrink it
