Is this really true?
So I'm at my LHS today and pick up some CA... and on my way out, he tells me to refrigerate it because it will last longer. Is this really true? To help with the situation this LHS sucks when it comes to r/c. they have r/c stuff in the window, but they dont sell anything r/c related inside! they dont really have anything there, and I was suprised to hear he had CA. Also, this guy also said to use ketchup as a cheap replacement for shock oil...
That comment was made to me, as they do not even sell shock oil...
There selection is literally this -T-maxx a- arms -3 nitro motors -some 5 year old nimhs -and some HPI spur gears. Thats it. No exaggeration |
I keep my CA in the fridge it really does seem to last longer . When i store it in my tool box it dries out . The ca in my fridge is at least 4-5 months old . I have been doing this for years .
My dad always used to keep super glue in the fridge, as well as alkaline batts. It definitely works for the ca style glues, plus when you use it cold it take a bit longer to dry, which can be good at times... Also it is bit thicker so it does not run between your finger and what you are trying to stick together.
As far as ketchup replacing shock oil... I guess if you wanted something thick, however when it heats up it changes consistency so it may not be the best condiment to use... Mayo would work well in the front diff, mustard would be good in the rear diff... Not sure what to put in the center, maybe some smuckers! As far as the shocks, I think some miracle whip would be best. |
Hahaha!!! Peanut-butter diff-lock.......... :rofl:
The chunky kind would have more of a "Posi Diff" effect. :lol: |
you can use superglue ( Cyanoacrylate) instead of CA glue( its the same thing) and it does come in a thicker version (gel) and back in the Vienam war the used it in the field in an emergency for covering up wounds
The solvents in CA are very volitile, so yeah, I wouldn't surprised if it lasted longer in a fridge as the cap has a poor seal. Personally I always just put it in a ziplock and it lasts long too, and is easier to take w/ you than a fridge.
As far as shock oil... I'm sure KY would work perfectly well also, but I don't know why you would do that. Even lst shocks aren't that big.. |
My friends' mom is a nurse and she always used super glue to seal our cuts up.
Yeah just don't use it on your eyes or other sensitive parts.
| All times are GMT -4. The time now is 10:00 PM. |
