-   -   Tekno Neu 1515 2D or 1Y? (https://www.rc-monster.com/forum/showthread.php?t=19474)
padrino 03.16.2009 08:13 AM
I have been running a 1515 2.5D in my e-revo for some time and like how smooth the motor is. I understand the difference in concept between the winds but don't know if the Delta wind is the reason it is so smooth, maybe it's just my imagination but I was hoping someone can confirm.
I am thinking about getting a motor for another e-revo build coming up soon however I am not sure if I should get a 2D (2050kv) or 1Y (2200kv). If anyone has suggestions please share.
azjc 03.16.2009 09:38 AM
whats your running style and voltage you will be using
padrino 03.16.2009 09:54 AM
Large majority of the time will be spent at 6S. Regarding running style, I am a basher cruising around the neighborhood and area construction sites, occasional speed runs but not much into back flips or crazy jumping.
teknorc 03.16.2009 11:54 AM
If you are running mostly on 6s, get the 2D. It will be a touch more efficient and run a touch cooler as well.
azjc 03.16.2009 12:17 PM
IMO I would stick with the 2.5d unless you like shorter runtimes and a hotter motor
