Traxxas slash brushless motor choice
I plan running my slash on 11.1v which motor do you recommend me ? I know mamba 4600kv and velineon 3500kv but I prefer lower-kv/higher-voltage..
http://www.hobbycity.com/hobbycity/s...idProduct=6527 or http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLXA0 geared jato spur 32p - 58t/15t @ 11.1v @ 28860 RPM = would give me tons of runtime & top speed of 40mph .. and should run cool since I dont pull alot of RPM.. im looking for something under 100$ but dont want feigao :neutral: |
get a feagio 9L with rcm clamp or a medusa 36-50-3300
anything less is a waste of time |
I always felt the feigao motors were better than the ammo motors I tried.
The medusa rootar mentions is the best bet... Slightly more than 100 bucks, but well worth it. As for the spinning toasters of death from UH/HC... Well that is just a waste of time. |
I think the velineon on 3s is a great choice. I really don't see why you would need much more motor in a truck that light, and tires that small. It has kept me content. I thought it ran fine with an L can 380 as well. I've had a couple of the bidproduct motors, def better than the hc ones, still would go with the traxxas.
MEDUSA MR-036-050-3300V2-3F this one too should be a good candidate I think :yes:
yup medusa 1st or 2nd a feagio, ive had a few 9L feagios with ALOT of running on them (talking over a 100 HOURS of use atleast worn out two 3s lipos on one motor......) they last as long as anything else when properly setup and taken care of.
| All times are GMT -4. The time now is 10:59 PM. |
