best screws for mounting a 1527 neu?
what are the best quality screws (flat head 3M) i can get to mount a 1527 neu?
Any grade 12.9 or if you can do it, drill and tap it for 4mm.
use mikes front end bell protector - then you get four screws into the can...
I use the cover on all my Neu motors, it also makes sure a scew wont get into the motor and make contact with the windings
You might want to check your motor since I have a 1527 and it has M4 screws
hmm:neutral:? according to this schematic http://www.neumotors.com/Site/Motor_...xxF%20-web.png all 1500 series motors are tapped for M3 screws. how can i be sure of which one i have? |
thanks
m4 threads are an option. Both of my 1521 motors have the optional threads and 8mm shafts.
http://www.rc-monster.com/proddetail...rontmotorcover I guess the countersunk holes are for motor screws, then it mounts with the other threaded holes? Is there one that catches all four screws on a Medusa? They have 2 on 25mm centers, but the other two are on 19mm centers. |
| All times are GMT -4. The time now is 01:52 AM. |
