my gear box and chassis fit...
man my gear box had a tight fit the rod (shift fork guide) had a hard time going into the hole I had to modify the hole a bit. Same with the bulkless setup there are two pins that the hole were too small for, but I got them in. Also the gear box does not sit perfectly on the chassis there is a little hump in front, but other than that the whole setup is nice I will take pics when im done with everything.
Good to here you got everything in there in one peice, as for the pins in the bulkless, if its too tight you may lose some performance in your truck as it will make the shocks work a bit harder, are you talking about the suspension pins or which ones?
Oh, ok than thats ok it can be a little tight.
What are you talking about " a hump in front"??
| All times are GMT -4. The time now is 07:32 PM. |
