My flm
http://img.photobucket.com/albums/v2...y/HPIM0217.jpg
http://img.photobucket.com/albums/v2...y/HPIM0216.jpg http://img.photobucket.com/albums/v2...y/HPIM0221.jpg Neu 1521/1y/s Flm Tranny forward chassis Flm Hybrid bulks Maximizer diff cups Savage XL outdrives and axles Alum. trans case hardened trans outdrives Cen 7.7 rims and tires Just waiting on the RX8 reviews to start, and then I will make my decision on whether or not I get it or the MMM. Pics don't show the color of the body right. It is spazstiks blood red with fasglitter red. Very sparkly. My gearing I'm starting with is 14/52. Is this a good starting point on 6S? Thanx alot. Mike |
Nice looking savage!
That is an awesome looking savage. And your gearing should be fine if you are still running the 2 speed as long as your batteries will fit.
Sweet looking ride. Great work:yes:
Nice Savage mate. Body looks awesome too.
A question, you say you are going to run 6S. How do you plan to mount the lipos? On the sides flux-style? I can't get more than 4S inside the FLM chassis without the batts touching the motor. |
My plan was to run a 6s brick. Flightpower makes a 25c 3200 mah 6s that would fit, my only concern would be the amp draw. I would consider flux style also. What would be better performance wise?
Thanx for all the kind words everyone. |
I guess it depends on cell width and gearing. Std 45mm wide cells (most available cells are about that width) still leave enough room to get most gearing options in there, if you use the 52t spur. |
Mike |
| All times are GMT -4. The time now is 10:12 AM. |
