Carbon fiber hinge pins-- cut your own.
Somebody posted this in another forum. I thought it was a good find since JDCarbon is out of Revo pins.
http://dragonplate.com/ecart/product.asp?pID=734&cID=39 You can buy stock carbon fiber rods and cut the length you need. |
How do CF pins compare to steel or Ti? I always thought that they would break easily.
I made some for a mini-t once. They wore out pretty fast. Some would break in bad cartwheel wreaks leaving a fuzzy carbon fiber split end.
My JD Carbon pins have held up great. The pushrods and tierods were not so great.
depends on what kind of cf it is i would think. the dragonplate rods are extruded right? very dense but might shear or fracture? directional (normal cf) wwould be my first choice(like i really know what the hell im talking about!!) if they would hold up for a season or so it would be worth it. what would you use to replace the 100 or so grams in your car? bigger motor? batteries? or run it "lightwieght"
| All times are GMT -4. The time now is 02:14 PM. |
