9xl and heat
I got a revo with an emaxx tranny on it geared 14/64 and stuck in 2nd. It's got the stock diffs and 40 series tires. I'm running a 9xl with 18 cells and after about 6mins of running, the motor is too hot to touch for more than a second. The 9920 and batteries are barely warm at all. Do these motors run this hot without a heatsink, or is my gearing all wrong.
Id try running a higher spur if possible, like a 72 t or a lower pinion, like a 12t, that should bring the heat down.
Wrong, sylvester. I think you have it way undergeared, slow-stampede. Get a bigger pinion!
Sounds like undergearing to me, too.
Although not always true, a rule of thumb is:
Hot motor, cool controller, cool batteries = undergeared Cool motor, hot controller, hot batteries = overgeared Warm motor, warm controller, warm batteries = happy components :) Hot, warm, and cool vary as well, so here's another general rule: Hot for a motor = generally over 160F Hot for a controller = generally over 150F (or "thermal" range for the controller) Hot for batteries = generally over 150F for nimh, 130F for lipo Warm for a motor = generally 100F through 150F Warm for a controller = generally 100F through 130F Warm for batteries = generally 100F through 130F for nimh, ambient temp through 120F for lipo Cool for all components = generally ambient temp and up to 10 degrees F more The reasons the above are not always true are numerous, but may include: Sticky drivetrain - will put un-necessary strain on electronics whether geared correctly or not. Poor quality batteries - batteries will heat up regardless of gearing. Wrong motor for the application - will put un-necessary strain on electronics whether geared correctly or not. Wrong controller for the application - will put un-necessary strain on electronics whether geared correctly or not. The list goes on, but this can give you an idea of things to watch for. Edited to add the following: Please note that this information applies to the sensorless brushless systems typically found here at RC-Monster.com (BK Warrior/Micro controllers, MGM controllers, BK motors, Lehner motors, Feigao motors). These rules do not apply to brushed systems or other brushless systems, at least not in the same ways. |
Great info guys....I had a feeling it was undergeared from reading all the other forums. I'll have to get a smaller spurr since that's cheaper than a bigger pinion :D I'll try 4-5 teeth smaller and see what happens.
I like to run my 9xl around stock gearing 18 66 or so. I have ran it with a 20 51 gearing. The motor was warm and the esc heated up. but it was fast
| All times are GMT -4. The time now is 08:28 AM. |
