Inferno gt owners!! I need diff advice please
What viscous diff fluid are you guys running in your gt's center diff? I got my car used and would like to change the fluid out for some fresh stuff.
spool...
on inferno gt i used a spool, or locked center diff......
Stops power being lost to front wheels during accereration which will give you masses of wheel spin and torque steer...
at on-road tracks I runned this thing with locked center diff the car was amazing......but several times the car went wheelies on the straights.......crazy........but fast.......with 50k oil it was great too........
I have used rubber silicone to lock diffs on many vehicles but not on anything this powerful should I use JB weld instead? I also found some 50k in my toolbox
Kyosho spool should fit fine. Hot Bodies, 777/IGT/ST-R Kyosho, Jammin, and most Ofna diffs are pretty close in size. You'll always need a few shims anyway.
I am going to be using a Slipperential so if I'm going to lock it I need a temporary solution that can be removed at some point if I turn the car back into a buggy. Does the Ofna Diff Lock lube work any good? |
| All times are GMT -4. The time now is 03:29 AM. |
