click when braking hard!
Just made a few runs tonight on a raze st and heard a click when braking hard a couple differant times. almost sounds like a diff .hard to tell which one. whats the best way to shim diffs? lmk.
phil |
check your output cup set screws/cvd setscrews. I had the same problem, and it ended up being a loose setscrew allowing the cup to rotate on the pinion. the screw hitting the edge of the flat spot was causing the noise
will check.. thanks
phil |
Having the same problem in the rear.
I think it is my pinion bevel and diff bevel gear no meshing right. might need a shim.
phil |
| All times are GMT -4. The time now is 01:30 PM. |
