8ight Diffs
Are the diffs the same in an 8ight Buggy and an 8ight Truggy?
yes most of the parts are the interchangable with the buggy and truugy
The ring gears for the buggy are 40 tooth and 43 tooth for the truggy. 13t pinion buggy, 10t pinion truggy, if thats also what you were wondering.
yeah, the diffs are very similar but dont try to switch them out. at first glance they look identical but they are slightly different in size and cannot be mixed. if you have a complete set of diffs and pinion gears for front and rear then that would work. just dont use the buggy diffs with truggy pinions or vice versa.
The parts are exactly the same except for the ring gear and the spur gear. So, yes they are very interchangeable.
Thanks
Thanks, that's the exact info I was looking for.
| All times are GMT -4. The time now is 10:34 AM. |
