E zilla
Hi everybody!!!
I know this topic had been discuss previously but will like to get the latest imput. Sure the E maxx have a lot of aftermarket support but the E zilla is what I got and whant to make it the fastest posible. Will like to know your recomendation for a brushless combo for my E zilla(Not received yet., on the way). What I want is a combo able to smoke the nitro monsters on drag and be able to run it at the dirt track. Will use lipo(3s). Thanks. :devil |
If I remember right. The tranny don't look like it can take but so much power. Only running 3s lipo will help keep power down. I think it was not a great deal of room where motor went. So not sure what you can stuff in there.
im pretty sure somebody on this forum runs a 9l and 9920 on his with 14 cells.
Thanks for the response!!!
Does anyone knows how is holding up that EZilla with the 9920 and 9L? Thanks:devil |
VWT4
Thanks!
Hey VWT4 how fast is your EZilla with that set up? :devil |
Are you be able to dust the nitro trucks with BL EZilla?
Thanks:devil |
You should hit mid thirties at least, so you should hang with most nitro trucks on 12 cells, and have more torque
Don't know if the diffs hold up!
The E-zilla is basically a Savage with a different center tranny/bits in the middle right? I'm thinking of getting one and throwing my 8L/Mtroniks Truck in it on 12 cells.
A 8L on 14 cells would be faster than the 9L on 16 cells using the BK 12020? What will be the pro and the cons of each one?
Thanks:devil |
the 8l will run a little hotter and give worse runtimes.
| All times are GMT -4. The time now is 09:20 PM. |
