-   -   clutch or pinion (https://www.rc-monster.com/forum/showthread.php?t=19794)
brian2njoy 03.30.2009 09:49 AM
clutch or pinion
I have the mmm conversion but the 5 mm pinion that came with it does not line up with the spur gear its like the spur gear teeth are bigger than the pinion teeth nay help or just run a clutch thanks
Arct1k 03.30.2009 09:53 AM
The MMM comes with an 18T 32p pinion - you need a mod1 pinion.
Check mikes store http://rc-monster.com/proddetail.php?prod=5mmmod1pinion
brian2njoy 03.30.2009 09:54 AM
thanks
Arct1k 03.30.2009 09:56 AM
No problem... Use this tool to work out your pinion size - Gear for 40PMH http://scriptasylum.com/rc_speed/
