brushless opinions for Backslash 1/8 scale 2wd buggy
Hey guys, first of all I guess I'll say Hi since I am new here, So....... Hi.
second of all, I am building a backslash as seen here, http://www.ultimatetraxxas.com/projects/backslash/ I am going to run a mamba max on 3s and a vxl motor, Unless you guys think I need to go with a lower KV motor? and if the VXL is fine could anyone reccomend where to start on gearing, i was thinking somewhere around 12-85 to 12-90 but that is just a shot in the dark from looking at soem other posts. all help is appreciated. and Linc FYI buddy I have some more questions coming for you in the near future. |
As for your slash buggy, the MM and vxl motor sound good to me. Not sure on gearing, but you can use BrianG's speed calc to figure gearing. It is listed in his sig. What lipo do you plan to use? |
right now i have one maxamps 3s 3000hv 60 amps continuous and a zippy 5000 3s 20c on the way I traded for. But will be looking for more once i find out if i can run this setup without overheating. if i can i want to get another 3s 5000 of some sort
| All times are GMT -4. The time now is 12:26 PM. |
