widest tire wheel that will fit 17mm hex
whats the largest (widest) Low profile tire and wheel combo that fits a 17mm hex
Probably a 40 series Wabash wheel with the 40 series tire of your choice on it.
Phaltlines... may not be the widest, but they are the lowest profile.
i had no idea that you could get 40 series or wabash in 17mm.
what about the widest wheel tire thats not 40 series that still use the 17mm? |
I got a set of the WB's in 17mm, they are 1/2"offset like losi wheels, you will add 1" total width at least to your revo
axial oversize rims also fit 40series tires and have 17mm hex
Axial
| All times are GMT -4. The time now is 02:31 AM. |
