Spektrum
I want to know if some people have the spektrum stuff. I having problems with glitch and stuff with my current set up. It is driving me crazy. If I get the new set up will it fix the problem. If not I am about ready to go back to nitro. :( I like the electric when it runs right. Some one please help me.
LOL..
one thing and he falls from his believe.. No schulze went up in smoke yet and you have got your doubts about electric.. To be honest; You life in the sticks, no one can be boughtered by a nitro noize.. You've got this K4,6 savage, why don't you try it as a smoker? |
Tried as a smoker. Kind of like it. But I like the electric to if I can get it to work right. ;)
What kind of system you run rene? Or any one else. |
Any one else has the spektrum? I like to know how it works with a bk and schulze controllers.
it shouldnt have ANY problems because it is make to eliminate all glitching because it constantly changes frequencies depending on other frequencies around. i think...
NOMADIO
Why nomadio?
nomadio is a pretty good system although i would say m8 or m11 with spectrum.
"1) We last longer on a charge.
2) We have 6 times the output power 3) We have built in telem included 4) We have full digital throuput not AtoD with the AtoD lag 5) We are FHDSS not parked on one ch. 6) We have feedback from the radio you can hear and feel 7) We are software driven so updates are simple downloads 8) We have 40 model memory 9) We have the same RF link as BOMB Squads use 10) We have a much higher frame rate 11) We send 32 packets of data per hop 12) We have a real time RF link quality graph so you can see exactly your RF output 13) We will not slow down as more traffic comes on 2.4Ghz 14) We will slow down other 2.4Ghz systems as they take time to reject our packets 15) Weight! 16) We can expand to more chs with software downloads if needed 17) We can select servo output High frame rate for digital and lower for Analog with no loss of speed per servo per memory. 18) We can remember receivers with no need to re-bind per memory 19) We can give YOU the ability to make your own programs with our developers kit. 20) We are so ugly that crooks will take a slow Bling radio first. " I pulled the above from a recent post onthis thread . Hear is another thread. |
It sounds expensive. I was looking at the spektrum kit that goes in the hitec agressor controller. I like my hitec controller it just don't work with my system at the moment. That sounds awesome though papa. I not sure if I need all that. I probably be the only man with 2.4 technology in the redneck basher club. :D
Im running a spektrum with my new rig and a BK controller with
no glitching at all. Not to sure what to recommend to you coolhand. Do you have access to a seperate rec to try to fault find. All wires intact, no cut or damaged wires? Power okay? Sorry mate, just trying to help as my system has been faultless. Dont give up on electric yet, I actually find my electric far more trouble free than my nitro. Good luck Tambo |
I am not sure, does the spectrum module even work with that radio?
It accually does papa. The modul in the back of the hitec is replaced with a spekturm. It even has it's own atenna. Is that cool or what. I have tried the system with different stuff. I am running out of options. I was told it was a compatiblity problem between the futuba and bk esc. I have the same problems with three different RCs. I run them all on the futuba. It does work great with the schulze and nitro.
Here is a site with it. http://rc-mushroom.com/product_info....oducts_id=6252 |
I knew it worked with Futuba, However i did not know that the hitec was a module based radio. I have been kicking around the 2.4 technology. I figure sooner or later all the major players will addopt it. If you already have a module based radio the spectrum may make sense. However, if you are going to get an updated radio the sensor seems to have all the bells and whistles, out of the box. I like the idea of being able to get updates/ upgrades without having to send in the radio. Cost wise for a new radio plus spectrum your in the same ball park as the sensor. Add in telemetry and the sensor is a better value. IMHO
Well papa the hitec is here with me. So all i would need is the spektrum part and a few extra recievers. Then I can play hopefully. I just wish I know whether it fix my problem for sure. I don't have a problem of buying it. Just don't want to buy it and have same issues.
They give a better discription here. https://www.ssl-stormerhobbies.com/c...=ns&pn=SPM1004 |
| All times are GMT -4. The time now is 10:49 AM. |
