pinion swap
anyone up for a trade? i got brand new 5mm 32p pinion gear 17T (novak #5157) also i got brand new rc monster hardened steel pinion gear mod1 14t.... i would trade for as big as possible 32 pitch pinion... both are 5mm bore and pinion traded needs to have that too.. i can consider givin both for 1 if so desired...:party:
i got a 16t 32p made by castle (its annodized green!)
i offered my 17t in trade... so i need a much bigger one... i got stock spur in e-revo and running 4 cell a123 cells 80A hw plus 9xl... so with those installed i need like a 25t minimum to even go over 30mph lol.... anyways i need a big 32p pinion OR i need a tiny tiny mod1 spurgear for the revo.. if i can use the nitro ones as direct replacement... 36T mod1 spur i think is smallest from traxxas... thanx for fast reply and offer though
Pete |
I have a 20T 5mm bore 32P pinion as well as a 56T spur and 58T spur. All are new, but the pinion is out of the package. Pinion is Robinson Racing and spurs are Traxxas. I'd trade the pinion and a spur for the 14T Mod1 pinion if you're interested.
I've got a 36t 32p 5mm bore pinion. brass sleeve in plastic gear. will that work?
pinion
sent both pm :) thanx for the replyes guys
the mod1 14t is traded if anyone needs the 32p 17t its still here...
| All times are GMT -4. The time now is 09:27 AM. |
