Slayer Transmission Problems
bashing around and it Quit pulling clutch bell gear and clutch is good spur gear and slipper clutch is good torn tranny down and no gears are stripped all look new any suggestions
When you say quit...what exactly happened....pics. would also be helpful
it just quit pulling would not go forward give the throttle and the to gears turned and no movement will try to get pics
Did you check your drive shafts/diffs. as well?
well you think both would go out at one time no wheels pulled and its 4x4
If all driveshafts are ok and the problem is indeed in the tranny, check the OWB on first gear and the small pins holding the gears onto the shafts.
DUMB question but how do I post pics here and OWB is good
When you respond to a post, don't use the Quick Reply, use the Post Reply button. There, you can add attachments, but are limited in pic dimensions and file size.
If the OWB is good (should grab in one direction and not the other), then look at the little chrome pins holding the gears to the shafts. These DO snap under BL power. If this is the problem, there is a sticky made in the Revo section (made by yours truly) that describes the "pin mod". |
Look close at the smallest white gear on the right. See the hole? The other side has a pin removable via hex drive. Pull it out and see if it's broken. The same thing is found on the other two shafts. Usually, the pin on the output and/or middle shaft will break first.
ok checked pins on gear in pic far right and far left they good don't see a pin on gear in middle of pic
Finally found problem pin on middle shaft was in three pieces had to destroy gear to get it out
hey Brian have you found any options for the slayer tranny pins for the middle shaft it's not a threaded pin just smooth looked at your pin mod thread and nothing there about that one any suggestions
That sticky does have the mods needed for each shaft; quoted from the sticky:
Another thread Completely Dominated by THE Brian G.
Go Big G! Go Big G!! Go Big G!! |
| All times are GMT -4. The time now is 07:17 AM. |
