haker c40 12t
hello a friend got a c40 12t and he like to get in a tt1/8 therm
for a conversion, is it possible? thanks |
Cant understand your point. Sorry, but please elaborate it further more, so we can help.
a friend like tu put this c40 12t in a mbx5 with 10 cells, is it possible? or the c40 12t is to small
sorry i m french |
It is about 3500 rpm's per Volt.
it should be okay on 10 cells. It takes a good controller though! it will sure take some Ampere! What gearing ratio are you going to use? |
i think i going tu use little ratio but i dont know exactly
i have controleur haker 125 amp, i think it s good what you think about performance with this? run time...... thanks |
Probably you are talking about the pro car controller. Yeah its a nice one. The c40 has a 380 size rotor and even if it was a 12 turn brushless, it would suck alot of amps. If you are talking about the L ( long rotor) size c40 then the possibilty is high that you will have more run time and power, but it is not a certainty with a s ( short rotor) size motor. However, speak to the people of hacker themselves, they would give you a pure answer. They reply fast, too.
The C40 12T which is almost the same as a Feigao 380 12s will have decent power on 10 cells and can be run on 12 cells.
I would think that the C40 12t would be a rather weak motor for a 1/8 buggy.
Not to mention that it is too small, its almost a 380 motor when the heatsink is gone. Great 1/10th motor though
| All times are GMT -4. The time now is 01:12 PM. |
