Problem binding Futaba 3PK to MMM
I have a steady green light on the RX and it is binded I think. I go to set up the ESC and full throttle turn on switch, get the solid red, then it turns solid green right away and when I go to full brake it blinks all the colors and the fan stays on. Any ideas? It worked fine with my Spektrum DX3s I am just trying to get it set up with my Futaba.
I got it nevermind.
Glad you figured out what the issue is.
For others with a Futaba 3PK and a Spektrum module, make sure you reverse the Throttle/Brake setting in the 3PK before attempting to calibrate the radio with the ESC (otherwise it will not sync). |
It helps to read the little manual from Castle where it says to reverse the throttle channel on Futaba radios :lol::intello::rules::rules::na:.
Glad you go it all sorted out. |
| All times are GMT -4. The time now is 01:26 PM. |
