Hyperion balancer pin assignment?
Hi there,
today i got my Hyperion 720 charger. The balaner-adapter for my battery is out of stock so I'm trying to improvise something to connect the battery anyway. With Google i found rather misleading info about the pin-assignment of the balancer-plug. Maybe you can help me out ... i want to connect my 3s-lipo to this: http://www.pipetrap.de/stuff/hyper720.jpg lets say its (from left to right) Pin [1 2 3 4 5 6 7 8] how do i need to connect my 3s-lipo there? many thanks in advance |
The connector should be wired like the far right connector in the pic below:
http://scriptasylum.com/rc_speed/images/balancer_Y.jpg In this pic, the clip is on the other side, so the last black wire should go into the far right of your pic. |
The Hyperion 7i comes with a different lead to the 6i - You'll need to wait - try allerc.com
thanks
well, ist aint working ... says balancer-error ....
btw im wondering, if pin1 (from my picture) is - or ground, why the red cable of the included connection-cable goes in there. Red should be + shouldnt it? maybe they turned it upside-down for this model? http://www.pipetrap.de/stuff/hyper3.jpg |
thanks again, now it works! .... hope LogView will support this charger soon ...
LogView supports the 0610iDUO v1 right now.Are you sure it doesn't support the 720 yet?
as i found out now it still wasnt right ... it has to start with the '-' of the first cell to the right Pin, not the '+' of the last Cell to the left pin :)
| All times are GMT -4. The time now is 09:37 AM. |
