-   -   New Savage project - stretched tvps! (https://www.rc-monster.com/forum/showthread.php?t=20077)
lincpimp 04.09.2009 02:30 PM
So I sold/traded my flm tranny forward chassis, and have a complete X just hanging around, never ran. I decided to pick up a flux motor mount and plate, and maybe make my own tvps...
Mocked it up using a stock X rear center driveshaft, and a lst1 wheel cvd for the front center driveshaft. This stretches the wheelbase to around 16". Gives enough room to mount the lipo in front of the tranny, inside the tvps. Plan to use some al servo mounts to mount the servo to the inside of the tvp on one side. That should give enough room to fit the lipo in there.
Going to run a 1515 2d and a 5s 5000 25c lipo. Might run a quark 125 or a MMM.
http://i206.photobucket.com/albums/b...p/DSCF3241.jpg
http://i206.photobucket.com/albums/b...p/DSCF3242.jpg
http://i206.photobucket.com/albums/b...p/DSCF3243.jpg
Takedown 04.09.2009 03:15 PM
Looks good so far linc. I look forward to seeing it finished. :great:
Always Dreamin 04.09.2009 03:33 PM
Sweet. You are talking about the origional 'X' right? Not the 4.6? I'm curious to see how the stock X diffs hold up to brushless without the metal casing. You might want to see how much you can get a new Flux gear box for. Probably would be way better then locking the plastic gears in 2nd.
lincpimp 04.09.2009 04:13 PM
I have the flux center shaft/gear coming for the x tranny (only difference is that part, everything else in the tranny is identical.).
Looking at body choices the firehammer mt body is just about right, and at 70 bucks not too bad. I would have to stretch the tvps out a bit more, looks like using a lst1 wheel shaft both front and rear as the center drives will get the stretch needed. Just need to pick up a few small parts and I can cut the tvps out.
Battery mounting looks pretty easy. I can use some of the thick delrin I have hanging around to make a battery try, and can also use that to tie the steering bellcranks to and mount the steering servo. The battery will have to sit slightly to one side but that will help offset the motor sitting on the other side. I will most likely mount the MMM as the flux mounts it. I may have to go bigger than the 1515 2d for this truck... Maybe the 1521 1y I have laying around... Plus I also have the flm towers and lst shock mounting kit. I doubt this will weigh much more than the flux, but I want some power.
drkdgglr 04.09.2009 04:32 PM
How about using the centre driveshafts from the LST XXL?
Always Dreamin 04.09.2009 04:33 PM
I thought the Flux had all metal gears? And a steel spur?
Or maybe it was just the spur....
Arct1k 04.09.2009 04:34 PM
Don't wus on us - We want to see a full diff or slipperential in there...
lincpimp 04.09.2009 05:11 PM
They are not long enough, one is the same length as the stock lst2 and the other is about 1" longer, they may be identical to the muggy driveshafts. The lst2 wheel shafts are about 1.5" longer than the stock lst center driveshafts, and compatible with most dogbone cups.
The flux has a full metal geared tranny. The X uses metal input gears, and metal output gears. The 2 speed larger gears are plastic in the X tranny, but they are replaced with a single steel gear in the flux. That gear and shaft are the only parts that you need to buy to convert the internals of the x tranny to a flux tranny. Part number is 100905, and it is available on ebay, bought mine last night. The spur is also steel, but I have a plastic 47t on there right now. With that spur and the flux motor mount a 23t pinion is about as big as I can fit... That is fine though, I only need about 19-20t on the pinion to get the gearing right. I also have a steel spur, but have found them not really necessary.
Ok, I can make a slipper style setup like the old slipperential. I would prefer more reduction than the pinion on diff provides. I actually like the savage tranny, but I would like to have the option of a locked 2nd gear internal ratio for a slower spinning motor. The flux tranny is effectively an X tranny locked in 1st. Good for faster spinning motors, like the cc 2200 on 6s, but I would like to have a low kv motor on 10-12s...
magman 04.09.2009 06:00 PM
Linc, what's up w/Donald duck! He must be your new helper!:mdr:
lincpimp 04.09.2009 07:44 PM
I found that digging thru some old stuff my mom gave me recently. Figured it would remind me of my youth... Maybe keep me a little younger at heart.
BL_RV0 04.09.2009 08:28 PM
Looks nice. I'd like to do something like this myself.
Always Dreamin 04.09.2009 10:13 PM
Ideally, that is what my sav would look like... in reality, nowhere close.
lincpimp 04.13.2009 04:48 PM
So I priced some bodies... Cough cough....:surprised:
After that I decided to raid my new body box, turns out I have a ford 650 body for the GST/Genesis. Has a 15" wheelbase, which I can accomplish by using the savage XL driveshaft in front, and the stock X shaft in the rear. That still gives me enough room for the lipo in front of the tranny, and I can use some regular size tires without the truck looking silly. Plus the overall size reduction over my previous plan will help out the power system.
So the current proposed setup will have similar specs to the savage xl, but will have a rear mounted tranny with the flux motor mount, and a forward mounted battery tray/servo mount. Not sure what tires to run, might get it all built and just go with what looks best.
Power system will be a 1515 2d on 5s with a MMM, or possibly a quark 125b.
I may still make a larger truck, but need to sell some stuff before I drop $70+ on a new body...
lincpimp 04.13.2009 05:03 PM
Did some more measurements, and the rear center driveshaft from the Muggy will fit better than the xl driveshaft, so I ordered one of those. It is slightly shorter, and with that the truck wheelbase will be almost identical to the bodies wheelbase.
Just need to snipe a good deal on a set of flux tvps and I will be able to cut the new tvps.
Savage03 04.22.2009 01:57 PM
Progress?
