F/S: Pro-Line PowerStroke Shocks + NIB Novak GTB 3.5
As title says, a full set of Pro-Line PowerStroke shocks for sale. Have about 3 hours of runtime on them, were re-bled from the stock 30wt to 35wt oil in the coil over shocks, 40wt in the bypass shocks (makes for a more progressive dampening feel) and have had about an hours of runtime since then. As far as I can tell the shocks themselves are in spectacular conditions. I do beleive one of the shock boots on the coil overs has a small tear but I was planning to put shock socks on the coil overs anyway (as it is what I recommend to the buyer). The by-pass shocks have intact boots that are ziptied at the base for security/seal. They will come with the original packaging and what is left of the stock 30wt oil. I will post pictures tomorrow. Priced reasonably.
(These are, in my opinion, by far, the best racing shocks available for a Maxx truck. Also a very good bashing shock. It is not the strongest, but it is well up there. These are the only shocks I know of that offer true progressive dampening via the bypass system and allow for tuning that isn't possible with other shocks. For example, heavier weight in the bypass shocks results in a more progressive dampening feel, while heavier weight in the coil overs just firms up the dampening all around. You can really fine tune the shocks in this sense. Allows you to be light and nimble through the rough sections but land the biggest triples smoothly.) Also, I have a Brand New in Box still sealed with shrink wrap Novak GTB 3.5 System. I have had this for a while and have STILL not used it. Obtained at one point to race touring cars, but that never happened. Priced spectacularly low to get it out of here. Can provide pictures as well but it is more or less straight forward. PM for Prices. |
When you get those pics tomorrow, PM me and I can either re-open the thread, or just PM me the image URLs and I'll edit your post...
| All times are GMT -4. The time now is 10:25 AM. |
