settings question
what kind of settings do you think are good for low temps on a motor , im running a MMM v3 with a feagio 8xl and geared 13/48 , and my temps were close to 200 on the motor , i want to keep the temps down as much as i can , thx joe
right now i have 50% punch and every thing else stock |
Increase punch more and lower timing. No matter what, Feigaos tend to run hot after ~10-15 minutes even in a perfect setup. You could try adjusting gearing up or down a couple teeth and see what works best for the temps.
Also, what kind of driving do you do? Lots of WOT runs with little stop and go: gear up a bit. Hardly any WOT runs, but a lot of stop and go: gear down a bit. |
i run on a small indoor track only WOT for mabey 1-2 sec :) lol so more punch , and lower the timeing ? last week we lowered the timing and it was CRAZY fast down the str8 and the motor was burning up like 200+ whats a no no point for feigao's?
You lowered the timing and it got faster?
| All times are GMT -4. The time now is 07:17 AM. |
