-   -   Lipos fully discharged (https://www.rc-monster.com/forum/showthread.php?t=20106)
twisted8 04.10.2009 09:40 PM
well i left my smc 5000 mah 28c packs plugged into my maxx and i just took em out and they were fully discharged.
they wouldnt charge on my lipo charger so i put them on my nimh at 1 amp for 5 minutes and then put them on my lipo charger.they are charging fine now.
question is did i mess them up ? are they dangerous now ?
lincpimp 04.10.2009 09:42 PM
If they did not puff you are fine... Just make sure they are in balance before you fully charge them. I would suggest a low charge rate like 1 amp or less. Then give them an easy run and see if the stay in balance. If they do you are good to go.
twisted8 04.10.2009 10:04 PM
i just charged one up to 7.70 and its balanced with no puffing. the 2nd one is on a low charge to get it up so i can put it on the lipo charger.
lincpimp 04.10.2009 10:40 PM
Sounds like you may be ok then... Just keep an eye on them!
twisted8 04.10.2009 10:48 PM
i got a lipo sack and they will go in there. should i put them out in the garage ? its cold out.
johnrobholmes 04.11.2009 09:59 AM
You want the cells to be warm when charging, at least 70f.
