-   -   Anyone know which cvd's will work w/the v3 Diff kit for the Revo using set back arms (https://www.rc-monster.com/forum/showthread.php?t=20183)
magman 04.14.2009 09:23 PM
Trying to figure out which ones will work and which one will not
BP-Revo 04.14.2009 09:49 PM
The Traxxas CVD's should work. Use them with the optional Traxxas outdrives which are designed for use with the setback arms.
You'll have to use the outdrive on top of the adapter.
shizzon 04.14.2009 09:51 PM
i should be getting my V3 diffs here anyday and i will report on how the work with my MIP 1665 cvd's. Im running RPM fronts and traxxas extended rears. I ordered traxxas extended drive cups for the rear just in case.
Ill let you know how they fit
magman 04.14.2009 09:53 PM
I installed the ext. cups already so I should be good w/the traxxas cvd
skellyo 04.14.2009 09:56 PM
If the MIP 1665's will fit, I have a set of 4 that I can give you a great deal on. I bought them, put a pair together and never installed them or even opened the second pair.
Arct1k 04.14.2009 10:53 PM
I use traxxas cvds with the traxxas extended cups with the swept arms...
shizzon 04.14.2009 11:17 PM
PM'd you skellyo
