Does anyone knows x1 CRT gear ratio?
Ep cars hv gear ratio does gp cars hv? It's not d diff ratio which is 43/13. Pls advise thx
Could you say that again? I cant follow what you said.
What you need to do is take the diff ratio and multiply it by your spur:pinion ratio. Truggies are direct drive, so there is no transmission gear ratio involved.
For instance: Diff Ratio: 43:13 Spur/Pinion: 62:13 Total gear ratio is = 43/13 * 62/13 = 15.775:1 1 revolution of the tires = 15.775 revolutions of the motor |
Or 50/11x43/13=15.01 or 50/11x45/10=20 Which is best final gear ratio? How's this final gear ratio? Will my esc n motor be too hot? |
A 36-70-1600 on 4S with 13:46 gearing should do ok. Likewise, 6S on that motor should do ok with that gearing too. The gearing on 4S puts you around 34mph and on 6S puts you around 50mph. |
Put all of the information in here and it'll do all the work for you:
http://scriptasylum.com/rc_speed/_top_speed.html |
just gear for 40-45mph and all will be well and run cool.
| All times are GMT -4. The time now is 06:51 AM. |
