-   -   Looking for a diff cup w/a 6mm bore and accepts a .304 ball end (https://www.rc-monster.com/forum/showthread.php?t=20194)
magman 04.15.2009 12:29 PM
I am using the 3095 trans w/the new revo v3 diffs... The cup sizes are different, traxxas vs the one that comes wMike's kit. So...In order to run dogbones in then cedter I need a new diffcup w/a bore of 6mm for the Trans. end and it must accept a ball end of .304"
I looked on tower, but, they don't give me enough specs. to be 100% sure. The only thing I thought of doing is getting a mugen diff cup and have it bored out to fit on the traxxas shaft
lincpimp 04.15.2009 12:31 PM
The mip cups for most traxxas stuff should do. If not I am 96% sure that a lst transmission output cup will do the job (you need the rear one as the front cup is hex shaped to accept the brake disk.)
magman 04.15.2009 03:16 PM
Thanks...I will look them up!
magman 04.15.2009 04:11 PM
I almost fainted...my LHS may have the diff cup I need...now THAT is a first!
