KV choices.
When will we see more KV choices in the 1/8th motors from Castle? I would really like to see a 1600kv.
The 1800 is in beta testing right now. Since they are using a 1Y in all their motors, they are lengthening the motors to lower the kv. At some point, the motors will be quite large and heavy, which is fine for larger MT's, etc, but too large for a buggy, and maybe even a truggy unless you want ridiculous speed and power.
I don't see why the 1800 wouldn't be just fine as long as it physically fits. The larger motor will stay cooler over a broader range of gearing. And if going to Medusa, I would go with an 80mm version for the extra cooling and torque in a truggy. I would only go with the 70mm if you were racing only and for short durations. In that case, less weight and lower torque might be better.
| All times are GMT -4. The time now is 11:18 AM. |
