-   -   Does anyone have an extra red jumper? (https://www.rc-monster.com/forum/showthread.php?t=2022)
JJJ 01.13.2006 02:42 PM
Hi
I drove my emaxx for the first time in June. I lost the red jumper on the first run. I havent run the truck since. Do any of you have an extra red jumper for the 9920 that you coul sell me.?
Thanks
captain harlock 01.13.2006 02:55 PM
I'm sorry, but I myself dont have an extra jumper, except for the one from the kontronik 40-6-18 esc and I dont know if it will fit in the 9920.
Gustav 01.13.2006 03:26 PM
You could use the black jumper if you're not using the internal BEC.It's the same(only black).
JJJ 01.13.2006 03:48 PM
I used the black jumper yesterday. Howwer th controller seemed to be running very hot with it. IU figured it needs the red jumper specifically?
Batfish 01.13.2006 03:54 PM
The color of the jumper shouldn't matter.
If you have an electronics store near you, stop in there with your speed controller and ask them if they have a jumper that would fit the spot you want it to. I'd expect they can help out.
Also, consider that all a jumper does is close the electrical circuit so you could even (carefully) solder a small piece of wire between the two poles to complete the circuit. Removal isn't as easy as a jumper, but it's less likely to fall off.
RCcarnut 01.13.2006 05:29 PM
I used a computer jumper on my 9918 without a problem.
squeeforever 01.13.2006 11:13 PM
most jumpers that the use on the back of computer harddrives are the same.
MetalMan 01.13.2006 11:35 PM
As long as the pin spacing 0.100", it should work. Most jumpers anywhere are that size.
Serum 01.14.2006 05:27 AM
Yeah, the computer jumpers are good to use.. Not the tiny jumpers used on scsi hdd's and cd-roms, just the big same sized jumpers on the mainboard/IDE cd-rom players..
Nick 01.14.2006 06:14 AM
If you have an old motherboard laying around. You can use the jumpers that reset the BIOS. Obviously, don't pull it out from a working computer.
sjcrss 01.15.2006 12:06 AM
jjj , if you send me a email with your address, I have a few old motherboards in my basement, and i can send you a few....don't worry about postage...here is my email addy
sjcrss@hotmail.com
shayne
coolhandcountry 01.15.2006 09:54 AM
The ones on the hard drives and cd roms work to. Just to let some one know.
