lst question
both my lst and lst2 have the same problem: the center driveshafts just barely sit in the cups on the transmission. Its breaking cups. Has anybody else experienced this? Any solutions
I have noticed this, but never broke a cup... I thought is was a bit screwy myself. Maybe a search for some parts is in order...
Wow
WOW I am surprized that James did not jump on that one and take jabs at you Harold. So I guess I will. It sounds as if your shaft is a little bit short on length Sir.:lol::rofl: Not that there is anything wrong with that.....:oh: Sorry could not resist.
If nothing else you can take some measurments and special order shafts from RCalloys. Have you tried using the fuel tubing trick to fill in a little on both ends, which should keep the shaft centered?? |
| All times are GMT -4. The time now is 04:05 PM. |
