killed a zippy?
Anyone has a experience like this? I set my esc to 4s. 3.4v cutoff. But during a race the car came to a dead stop.
I check d esc it's ok, check the batt foundout 1cell in zero volt. Any idea way went wrong?thx |
cut off not engaged?
i can't find another explanation.... |
Did the wires come loose from one of the cells?
no but 1 cell is dead three other cell is abt 3.8v but the total volt is 7.5v y? i tried to charge but no batt detected, i used a volt meter no volt detected also. i suspect some wires in the lipo is loose.
anyone managed to get a replacement from hobbycity? |
I think a few people have been successful who had issues- hobbycity do have good aftersales support apprently- well worth contacting them.
Thx guys, managed to contact hobbycity n sent back the pack.
how old was the pack an which zippy pack was it?
This is why zippys are cheap and why you should tape the cells together. When you get a pack back, I would recommend taking the shrink off, taping the cells with packaging tape or something similar, then re-shrinking the pack. It will keep the cells from shifting and the solder joints from coming undone.
I am running 2 3s 5000 and the frist thing i did when i got them was cut the pack opan and resolder all the conections, than re wrap the pack like metallover said. Since than i have never had a problem with the lipos. I look at it like another 15 minutes verses the money i am saying, it is well worth it
| All times are GMT -4. The time now is 02:46 PM. |
