What would it take?
To get this motor in my VXL Rustler? I already have the Medusa 36-50-3300 just would like to run this motor in it instead. I am already running 5mm 0.8 gears. Thanks
http://cgi.ebay.com/NEW-Castle-Creat...3%3A1|294%3A50 |
FLM tranny. Gearing will be limited.
What speed are you aiming for? There is a big difference in kv.
You'll need a crazy gear ratio to use that torque...
You'd probably be better off getting a 1512 in a higher KV rating. |
IMO I would keep the Medusa and run it on 4s lipo if you want something crazy, I have a VXL Rustler with a Feigao 9L with 4s and it kicks ass, my 9L has a lower kv than your Medusa at 2700 . I run MOD 1 gearing using a Revo 40 tooth spur with a 16 tooth pinion
| All times are GMT -4. The time now is 09:37 AM. |
