-   -   drift practice vid - xray t2 (https://www.rc-monster.com/forum/showthread.php?t=20388)
DickyT 04.23.2009 09:26 AM
http://www.youtube.com/watch?v=3s3ZyoaECmk
A little practice last night for this saturday's competition.
magman 04.23.2009 09:48 AM
Nice! I have never really watched drifting before...seems to require a ton of precise control
DickyT 04.23.2009 10:12 AM
Thanks! there certainly is alot of skill and control required. A month ago there is no way I could have got the car through those tight areas I made,now I find it pretty easy.
Andrew32 04.23.2009 11:49 AM
SICK! jsut SICK. I have to heavy of a finger to do that...
js058515 04.23.2009 01:28 PM
That was nice to watch......Can you post your exact set-up? I have been thinking of dabbling in an on road drift car but am not sure where to start.
bigboi146 04.23.2009 01:34 PM
Your very good at that... I don't think I could get that close to the wall without breaking parts... Good job!
What tires are you using?
BrianG 04.23.2009 01:45 PM
Nice driving. I can do that too, but only if the cones are about 50 feet apart. :smile:
Do you use the D-box or similar? Or is it all you?
DickyT 04.23.2009 01:45 PM
Thanks all!
I am running an xray t2, novak slyder esc with 7.5 slyder motor and a 6.00 final drive ratio. loose ball diff front, spooled rear, 1 degree toe out front, 2 degrees toe in rear, -1.5 degree camber all the way around. The front shocks have 25 wt oil, 14lb srpings, 4 hole pistons and are positioned on the middle tower hole. The rear shocks have 25wt oil, 17lb springs, 4 hole pistons and are on the second hole form the outside on the tower. The tires are hpi t-drift.
