ezrun 150A
How I need to configure the ezrun 150A??? it is going to run my e-maxx with a neu 1515 2.5d
it is the programmable items: http://www.hobbywing.com/upload/car/...zrun80_e_s.jpg Regards |
Start with default settings and see how it runs. You do not need to adjust timing as delta-wound motors are insensitive to timing changes. Do NOT adjust punch to "0". I wouldn't go below "3". Set your Low Voltage Cutoff for LiPos if you use them. Aside from that, you're fine.
| All times are GMT -4. The time now is 08:21 AM. |
