Castle conversion kits
Has anyone heard the latest on the conversion kits from castle.
At RCX they said mid to end of May.
Any list of models that will; be available?
On the website where they show a small picture of the kit is a small list of models available
Losi, Jammin, Kyosho
Followed by: Hot Bodies, Associated, |
Any chance of making kits that will fit the inferno GT, inferno GT2 and STRR. I emailed Joe about this and he said the current Kyosho kits will not fit these cars.
Are the kits just for buggies, or truggies too?
I think they are just for the buggies. I would be really nice to see them made for the truggies as well. What i really like about them is that if puts the motor on the left hand side so if you wanted to you could run a mechanical brake setup
Mechanical brakes is not determined by which side of the diff the motor is on - not sure where you got that idea. The Castle mounts aren't set up for mechanical brakes(not drilled or cut to accept them).
Thanks mike. I just thought that with the motor being on the right it would give me room to mount the original brake servo.
| All times are GMT -4. The time now is 11:28 AM. |
