range issue with d3xs
after my mmmv3 died today now its time to my brand new dx3s to have issue...im not able to pass 100 feets without the esc cut...or loosing bind...:grrrrrr:W.T.F all this problem became to make me feel very sad....im really close to sell all my stuff...o yes very close:diablo:
ive tried 3 other rx and same thing..... |
another mmm v3? also, does this happen in other instances? like what if you take the tx and rx to a place you normally arent at, have the rx just powered on from a rx pack, then test range... Also, make sure your rx isnt loosing power. I thought I had the same issue in my rustler, but it was my BEC shorting and cutting power to the RX
Same thing happens with my DX2.0 about 100ft down by my neighbors house. Its unexplainable and was a freak thing. My thought is a trucker with a CB radio was driving by and caused some freak reaction.
And as said before, a number of things can cause Spekky radios to go bazerk. CB radios are, as far as I know, the number one cause. Maybe like what happened to me, a trucker drove by and caused your DX3S to go nuts? Or maybe a plane/heli? Could be anything. |
i just changed the setting in my tx(frame rate)and now its seem better:whistle:dont know if this setting could help but its seems to work...
Could be a brownout, have you tried elsewhere?
I had the same issue with my DX3s. It glitched a couple times and cut out. I replaced the batteries and it seemed to clear up the symptoms. I did buy a Futaba 3pk FASST though and would never look back.
http://i39.photobucket.com/albums/e1...6/100_3410.jpg http://i39.photobucket.com/albums/e1...6/100_3407.jpg |
this is the thing that i want to do...trade my dx3s for a 3pm or just buy a 3pm
but tonight ive try elsewhere and everything was ok....so maybe a bad signal in my area:whistle: |
| All times are GMT -4. The time now is 10:25 AM. |
