any ext. suspension arms for 3905?
I want to know if i can get longer arms than the stock set and if so where from. I'm not worried about th edrive axles, i'll get that soughted. Any in put appreciated. :smile:
Doesnt exist.
You can however get extensions of a sort: http://204.186.93.64/E-maxx1-6ScaleConversion.htm They screw into the ends of the arms to widen the track width, looks like this only with emaxx arms: http://www.fileden.com/files/2007/10...onWidening.jpg You could also try offset rims and/or axle extensions, but those put more stress on the bearings in the knuckles.. |
thanks suicideneil. I may get those extensions because i already have hub ext.'s but I don't like the axle carrier being exposed. :yipi:
| All times are GMT -4. The time now is 07:58 AM. |
