2650 on 5s hotbodies lightning street 1/7 (hehehe)
Well i pulled the esc out of my buggy because i wanted to get a testrun in on my 1/7th scale lightning street.
castle neu 2650 mamba monster 18/44 13/43 diffs http://i54.photobucket.com/albums/g1...90428-1207.jpg http://i54.photobucket.com/albums/g1...90428-1206.jpg so i take it out and get some good passes and its hauling i would roll into it till full throttle and it was flying down the street. it would start to skate around as i hit full throttle... well i got into it to hard and the front end unloaded and so did my tire it ripped itself into pieces. http://i54.photobucket.com/albums/g1...90428-1203.jpg so i went to the tire bag and grabbed a bald set of buggy tires i had and threw them on well they fared a little better but they're now trash http://i54.photobucket.com/albums/g1...90428-1257.jpg so all in all it was fun and hopefully ill have some video next time. btw motor temps never got over 110 esc i got the fan to turn on temped at 155 and the battery was 110 that was after a good 10 minutes of running |
always have video rolling, sheesh:lol:
What mount did you use for the motor? I have a LS too, and want to convert it!
i used the caster racing mount out of the fusion because i had one laying around i used the whole caster diff mount and diff also
Also The batteries were 5s 5000mah 15c trueRc Packs hopefully i can radar it next time also
Any reccomendations for tires that wont explode and a reccomended diff fluid so the front end doesnt unload
rchippie had a line on some belted tires. Maybe contact him? I plan on getting some for my Ultra GTP since I trashed the stock tires.
Edit: Found what I was referring to: http://www.rc-monster.com/forum/showthread.php?t=15905 |
Hard shore foams would hold up better, but I doubt that they would wear well. |
Just curious, what would the purpose of a CD serve in an on-road car? I would think a solid center drive would be preferable.
i just ran it this way because i had the diff and a regular pinion im going to order up the rcmonster 2speed parts and we can see what happens after that.
I don't know about linc, but the one time I got into second gear, the torque broke all 4 tires loose and lost control until I let off the throttle. Wasn't fun for me. Great for speed runs but not so much parking lot/street bashing.
[OFFTOPIC] Does anyone make a "generic" locking center hub for the typical 46T CD spurs? I know a select few vehicles have that as an option, but was thinking more general purpose. This could either be a center diff insert or a different unit altogether. The GTP has a single speed option, which I'm using, but it's made for 51T spurs, which are too big for normal buggies/truggies. [/OFFTOPIC] |
Yes the CEN locker works
ofna has on in the oval car kit but i cant find the part number
never mind its 51 tooth like you said
| All times are GMT -4. The time now is 12:26 PM. |
